Part Number: TRS3223E
Other Parts Discussed in Thread: TRS3223
Voltage vibration at high/low voltage level,
Pls see attached file in details, Thank you.TRS3223.pptx
Hi Mark,
This ripple is caused by the charge pump circuitry which drives the RS232 signal high and low.
This charge pump blog post describes the affects of capacitors C1, C2, C3, and C4. Changing the ratios of these capacitors determines several effects such as ripple height and ripple frequency.
Tyler
Hi Mark,
Yes there will be ripple on RS232 signals HIGH and LOW. If you meet the recommended operating conditions for Vih/Vil, the voltage ripple will not impact RS232 data transmission. The voltage ripple is caused by the charge pump circuitry driving the signal high and low... this is normal operation of the device.
Tyler
