DS90UB953-Q1: please help share DS90UB953-Q1 24M clock configuration data
Part Number: DS90UB953-Q1
Dear TI specialist,
customer need configure 24M clock,can you help share the register configuration data?thanks.
below is the schematic for your reference.
  • Hello Cickey,
    Can you please share a pdf version of your schematic? I am not able to view this picture clearly.
    Are you using the synchronous mode? Please confirm.
    You will need to use the correct strap (see Table 7-8. Strap Configuration Mode Select). Make sure 0x03[4] is the correct setting if you are using the strap mode pin to set the mode.
    Shruti
