Part Number: DS250DF410
Other Parts Discussed in Thread: DS125DF410
I would like to ask you a question about the value of "Reg 0x64" from my customer as below.
1) Setting value
Let me comfirm that we can set the "lock range" of the signal by this register, correct?
As the default value of the register is 1000ppm (0xFF), is it possible to change/set the value 100ppm?
2) Setting procedure
If we can change the value, will you please tell me the register setting procedure?
Thank you for your support.
Takumi
