Part Number: TCAN1042HGV-Q1
Hello team,
I want to check with you, if we can also connect the STB directly to GND if not needed or do we need a 10k Ohm resistor?
Matt
Hello team,
Matt
Hi Matt,
The STB pin may be tied directly to GND if the standby function is not needed. Because this pin has an internal pull-up to Vio, an external pull-down would help limit the leakage current through this unused pin (-20uA max when tied directly to GND).
Let me know if you have any more questions.
Eric Schott
