Part Number: DS90UB953-Q1
We have implemented POC filter for 800mA POC current ("Murata solution #1) provided by TI.
We're now measuring high reflections on 160MHz that are eliminated when the POC (L1) inductor is removed
This (graph below) is the measured RL, the relevant problem is shown in the circle
This is the POC filter we use:
We think that parasitic capacitors could be eliminated if we optimize the layout under the the inductors.
Can you share your layout implementation for the filter or provide recommended layout guide lines?
p.s. Can you confirm that the same POC filter can be symmetrically implemented on the deserializer side?
thanks a lot,
amotz
