Part Number: TMUXHS4212
hi sir
I download the switch "model S11-parameter sim tool" from TI web, and load the TMUXHS4212 pattern
I Get the below chart. over the 0db, that is right?
hi sir
the measurement is not accurate at high freq. what freq range you are interested?
brian
Could you help to check it?
model S11-parameter sim tool,TMUXHS4212 pattern which is error?
Alex:
the error could be caused by the board used for this measurement. So the data took over 15g is not accurate.
brian
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/a0b0_2D00_on.s4p
pls check this file. We measured upto 40Ghz, but only good upto 23Ghz.
