Part Number: LMH0397
Other Parts Discussed in Thread: LMH1297, LMH1297EVM
Dears, i will use the LMH0397 in a new project. I need info about evaluation board. Is there a code for this board?
is it available?
thanks
is it available?
thanks
Hi Nasser,
thanks for your reply.
I understand that LMH0397 and LMH1297 use the same evaluation board, but i need the info for order the test board with LMH0397 device assembled.
Are there two different order code ?
Hi Luca,
LMH1297EVM does not come or LMH0397 is not mounted instead of the LMH1297 device. There is not a board with LMH0397 mounted. Please note LMH1297 and LMH0397 are the same part but in one part - LMH1297 - 12/6G are enabled, tested, and checked.
Regards ,,Nasser
