Part Number: DS90UB941AS-Q1
Hi team
My customer Yanfeng Visteon has an application which contains a cluster + an Infotainment display (IVI) and both of the PCLK are roughly 96Mhz. They would like to use 941AS splitter mode with 2*948 to implement this application scenario.
Since we all know that 941AS could support 105Mhz per link, and about the cluster, car OEM would not permit to lower the frame rate(which means keeping 60hz), so TIER1 and car OEM are afraid that 96Mhz is so closed to 105Mhz. Do we have some test results like EMC/eye diagram for 941AS splitter mode with such high PCLK or could you please kindly to confirm that whether it is OK with 96Mhz per link with customer's application? Thank you in advance!
