Part Number: DP83TC812S-Q1
Other Parts Discussed in Thread: DP83TG720EVM-MC
I’m confused by the LED strap connections on the DP83TC812 device. The datasheet has two modes for the LED pins.
Figure 7-5 shows the LED strapping, but doesn't identify which Mode is associated with each picture. And, it uses Rp as an identifier.
Table 7-5 shows what to use for Rh for Mode 1 or 0, but Rh doesn't appear in Figure 7-5. This is confusing.
What LED strap connection do you use with mode 1 for the LED pin?
thanks
