Part Number: HD3SS213
Hello expert,
Customer would like to know the difference between hd3ss213ZQER and hd3ss213ZXHR. Could you kindly help to provide the difference for us? Thanks a lot!
Ann Lien
We only has ZXHR, where did you see ZQER?
Hello Brian,
This is from old version solution and customer is using old footprint for HD3SS213. May we know if you can check internally to see if there is any comparison table for it? We just want to know if there is anything need to change when customer changes footprint from ZQER to ZXHR. Thanks a lot!
Ann Lien
Ann
The nfBGA package offers data sheet-equivalent electrical performance and data sheet-equivalent or better thermal performance. It provides the same X and Y dimensions as MicroStar BGA, and provides pin-to-pin and footprint compatibility. The nFBGA PCB land pattern and stencil recommendations have been updated to achieve better soldering results after extensive testing and evaluation.
Functionally the two packages are the same.
David
