Other Parts Discussed in Thread: DP83869
Hi!
How do I convert 10/100 copper ethernet to 1GbE fiber?
Can you send me a schematic?
thx,
Phil
Hello Phil,
Thank you for the query.
Based on your inputs, i assume you are looking at media converter application. Looks like DP83869 may not be able to support the required configuration.
Please refer to the below section in the datasheet,
9.5.1.8 Straps for 1000M Media Convertor
If there are any additional inputs you have on the use case, i can check the feasibility
Sreenivasa
Hello Phil,
I am closing the thread since i have not heard back from you.
Sreenivasa
Hello Phil,
Sreenivasa
Hi! Can you recommend a switch chip that could convert 10/100 copper ethernet to 1GbE fiber?
Hello Phil,
Thank you for the reply,
I do not have a part number in hand that i could share.
Sreenivasa
Hello Phil,
I will close the thread since i have not heard from you.
Sreenivasa
