TCAN1042H: spec check
Part Number: TCAN1042H
Hi
Is there a Support CAN BUS FD and socket can solution that can be recommended? Customers need to support X86 platform and Linux driver, please help me to confirm~Thank you.
  • Gareth,
    Can you elaborate on what is needed from the CAN transceiver? The processor and driver should be irrelevant to the transceiver as long as the data rate and voltage levels are supported by the transceiver. Maybe sharing a block diagram or schematic would help.
    Eric Hackett
