Part Number: TFP410-EP
Other Parts Discussed in Thread: TFP410
I am evaluating a TFP410MEP DVI/HDMI transmitter.
Most functions seem to be OK. I2C is working RGB data is recognized correctly (H_RES and V_RES registers are correct).
Confusingly I can measure the pixelclock on DVI side on pins 30 and 31.. I had expected the clock output on TXC+/- pins or pins 22/21.
According to datasheet pins 30/31 are TX2+/-.
Is there a version with reverse DVI pinning? If yes, is there a datasheet for this version?
Is there anything else that could cause this problem?
Thanks for help.
