Part Number: DP83867IR
Other Parts Discussed in Thread: DP83869
Hi Team,
Quick question, can this device support 1000-BASETX protocol ?
If not, which one in our portfolio can support?
Thanks!
Andrew
Hi Andrew,
We do not have a PHY that supports 1000Base-TX. We do have PHYs that support 1000Base-T.
Thanks for the feedback!
May I know which TI PHY can support 1000Base-T?
Thanks!
Andrew
Hi Andrew,
DP83867 and DP83869 would support 1000Base-T.
Sincerely,
Gerome
Hi Gerome,
Thank you.
Just double confirm with you, customer wants to make sure the connection like below works, thanks!
RGMII - PHY(1000Base-T) - PHY(1000Base-T) - RGMII
Andrew
Hi Andrew,
This configuration should work assuming both of the PHYs are either DP83867 (any version) or DP83869.
Sincerely,
Gerome
