Part Number: ONET1141L
Always Thank you for supprts.
I have a question about the APC operation of ONET1141L.
I am currently using the ONET1141L to evaluate pulse driving of Laser Diode.
1. Please explain the APC control operation in APC mode (in closed loop operation).
I think APC control is controlling Bias current by LD light intensity (=photodiode current).
Does the APC have control to increase or decrease the BIAS current?
(Does APC provide control to increase as well as to decrease BIAS current?)
We have confirmed that when the duty cycle of the modulation current is changed, the BIAS current increases or decreases in accordance with the change in light intensity.
(Bias current decrease, Duty down --> Bias current increase)
I have determined that it is working correctly as an APC control, is that correct?
2. Please explain about Bias current control in APC OFF mode (in open loop operation).
When the duty cycle of the modulation current was changed in the APC OFF mode (in open loop operation), we confirmed that the BIAS current increased or decreased according to the duty cycle change, just as in the APC mode (in closed loop operation).
It seems that the operation in APC OFF mode (in open loop operation) is not correct.
(I suspect that the Bias current will not change?)
Do you have any advice for this phenomenon?
Thank you.
