Part Number: DP83822IF
Hi team,
My customer reported an issue with DP83822IF. The device is operated in 100BASE-FX mode. Sometime the link partner may send a wrong idle symbol. Normally the idle symbol is 62.5M, occasionally the link partner may send a 41M signal. The fiber link dropped in this condition. That is ok, while the problem is the link cannot be established automatically after the partner resumed to send correct 62.5M idle symbol until the fiber cable was manually disconnected and reconnected again (resetting DP83822 in software cannot establish link). This is unacceptable. Customer told me other phy devices, such as ksz8041 does not have such problem.
Is this problem related to some register configuration? how should customer solve this problem?
Thank you!
John
