Part Number: DP83822EVM
Other Parts Discussed in Thread: TIDA-00928, DP83869, DP83869EVM
Hi
The optical transceiver used by the customer is TRSL-7110ACG, and the specification is as attached How to connect DP83822 EVM to make it work At present, remove T2 from DP83822 EVM, and connect RXD_P, RXD_N, TXD_N, TXD_P to TRSL-7110ACG After connecting the optical fiber Switch HUB, it is detected that the optical fiber is connected, but normal communication is not possible Are there other lines that need to be modified? Please help me how to connect TRSL-7110ACG so that it can work normally
