Part Number: DP83848LFQ
Hi Team,
There is a good new that we DIN DP83848!
What deference between DP83848LFQSQE & DP83848QSQX/NOPB ? THX
Can DP83848LFQSQE replace DP83848QSQX/NOPB?
Can it be replaced without any H/W and F/W change?
Hi Team,
Hello Kygo Cheng,
The below part says as preview. Not sure if you would want to recommend this part.
https://www.ti.com/product/DP83848LFQ
Do you have some inputs on the application and if this is already in production - > a schematics.
Sreenivasa
Hi Kallikuppa Sreenivasa
Can DP83848LFQSQE & DP83848QSQX/NOPB be replaced without any H/W and F/W change?
Hello Kygo Cheng,
Thank you for the reply.
Are you checking if these can be interchanged ? Is see LFQ as preview. Not sure on availability.
Regard,
Sreenivasa
Yes , we want DP83848LFQSQE interchanged to DP83848QSQX/NOPB!
Need H/W and F/W change? THX
Hello Kygo Cheng,
Thanks. You want to replace DP83848LFQSQE with DP83848QSQX/NOPB. I assume my understanding is correct.
I will review and provide my inputs.
Sreenivasa
Sorry, Exactly the opposite!
We want to replace DP83848QSQX/NOPB with DP83848LFQSQE, THX
Hello Kygo Cheng,
Please note that the device is mentioned as preview. I am not sure if the device is available.
Have you confirmed the availability of the device ?
Sreenivasa
Cause DP83848QSQX/NOPB is out of stock
1.So I would like to promote customer use DP83848LFQSQE ,because it is preview(I think it will easy to get sample in the future )
2.Or if you have a suggest solution for me to replace DP83848QSQX/NOPB, please let me know ,THX
Hello Kygo Cheng,
The DP83848 is a matured family and i do not know why the device is in preview.
Anyways i will compare and update you.
Sreenivasa
Hello Kygo Cheng,
There is a difference in package but should be usable without any hardware change.
Sreenivasa
Hello Kygo Cheng,
Thank you. If you do not have additional questions, please click the resolved button to close the thread.
Sreenivasa
Hello Kygo Cheng,
I expect similar functions to work without any firmware changes. This is something customer will still have to test.
Sreenivasa
