Part Number: SN75DP130
Other Parts Discussed in Thread: TDP142
We will be launching a board redesign to eliminate the DP130. Which component do you recommend we implement as the replacement for the SN75DP130?
Possible replacement is SN65DP141, https://www.ti.com/lit/ds/symlink/sn65dp141.pdf, or the TDP142, https://www.ti.com/lit/ds/symlink/tdp142.pdf. Both are DP linear redrivers vs. the DP130 limited redriver solution.
David
