Part Number: TCA9535
Hi team,
When there haven't POR yet, how is the output state at each pin (/INT, SCL/SDA, Px)?
Hideki
Hi team,
Hideki
Hi Hideki,
The first time this device is powered on for its application, the following pins will go to their default state:
SCL/SDA = High-Z inputs
Px = High Z- inputs
/INT = Active low Output connected to VCC through pullup resistor (typically 10kohm)
Tyler
Hi Hideki,
I realize that this may not be the answer you are looking for. Give me till 5pm tomorrow to get back to you with a more correct response. You are interested in the output state of each pin before device is powered on for the first time, not after a POR, which I gave below.
Tyler
Hi Tyler,
Yes, the latter is what customer needs to know. Appreciated for your support, and thankful for your self correction.
Hideki
