Hi.
My customer has the following questions. Could you please advise us?
*1.
According to datasheet P.6, parameter R(VBUS), (External resistor on VBUS_DEC pin) is Min 880, MAX 910ohm. On the other hands, on datasheet P.7, parameter RVBUS is Min 855, MAX 920ohm. So we are confusing. Why is different? Could you please let us know the recommended pull-up resistor value?
*2.
According to datasheet P.5, we can find the typical 200kohm on R(p_ODext) External pull-up resistors on Open Drain pin. We seem these resistor's value is pull-up to 5V. How about the resistor value on 3.3V pull-up? Could you please let us know the recommended external resistor values on 3.3V-pull-up?
Thanks and best regards,
M.HATTORI.
