Part Number: SN65LVCP114
Other Parts Discussed in Thread: DS125BR401, DS125MB203
Dear teams,
Customer have some questions about the SN65LVCP114. Could you help assign an AE to take a look on that? Attachment is the planning solution based on customer needs.
Customer requirement: Input signal is from Serdes: differential input (one pair); Better to support USXGMII and XFI; Output better to have 4 pair differential output (8 signal chain), at least 2 pair output to do cascade to achieve 4 pair output; Data transmission rate 10G;
After my investigation, I found SN65LVCP114 might be the good one to match requirements; However, this device can only support 2 pair differential output, and it need to do cascade at the output to achieve 4 pair differential output.
Support need:
- Could you help recommend the best device to match customer requirements?
- If we don’t have the device to match customer devices, do you think whether SN65LVCP114 cascade structrua can meet customer requirements or not?
- Whether SN65LVCP114 can support SGMII/HISGMII/USXGMII/XFI?
- Are there any performance difference between customer used CIN0P/N(INPUT) AOUT0P/N (OUTPUT) and CIN0P/N (INPUT) BOUT0/N (OUTPUT)? Aout and Bout will be the output simultaneously? Aout and Bout was not the switcher to determine the output, am I right?
Thanks!
Dylan
