Part Number: TUSB564
Other Parts Discussed in Thread: TPS65987,
Hi team,
Could you please tell me how to TPS65987 GUI to control the EQ value.
If we have related information or example could you share with me?
Hi Jason,
We have application note to describe how PD program other devices through I2C3m.
You can follow the note. And for the selection of value of EQ, you need to refer to TUSB564's datasheet.
Hi Bing,
How to set the EQ with I2C mode, in datasheet there is no reference table could set the EQ value.
Jason
Bing is out of the office for Chinese New Year. He will address this when he returns.
Hi Jason,
Yes, the EQ value may not be included in PD's app note, we can just follow TUSB564's setting to send out I2C playload.
For the content of payload, you have to ask TUSB564 apps to get the setting, and then we can help you configure that value in PD's configuration.
Thanks.
Bing
Hi Jason,
You need to follow the below writes to the I2C registers. Table 7. TUSB564 Receiver Equalization GPIO Control shows the EQ settings which are the same for I2C mode.
Each nibble controls the EQ values for a specific channel as defined n the datasheet. Valid data in each nibble will range from "0"-"F" in hexadecimal. Specific setting will vary based on channel loss and test/ compliance results.
