Part Number: TPS25832A-Q1
Other Parts Discussed in Thread: TPS25831-Q1, TPS25833-Q1
Hi kuno,
As you know TPS25832A-Q1 ic has data line (DP_OUT, DM_OUT). but I dont want to use them. I only want charging the devices. Charging the Type-Cs.
Is there any problem that you may think that do not using the data lines? If I do not use them, is there any problem to charging the devices?
Mehmet ÇOBAN
