Part Number: MAX3243E
Other Parts Discussed in Thread: MAX3243,
Hi All,
I would like to know the exact difference between E & non-E versions.
As you mentioned the main difference between E & non-E versions is on the ESD Spec.
And the "Maximum data rate" : 500k bits (E) v.s. 250k bits(non-E).
Except for the above 2 points, could you kindly help to confirm whether I miss something in the datasheet(internal logic/structure...)?
Thank you all.
