Part Number: DP83TC812S-Q1
Hi Team,
My customer is trying to find a way to disable the 812 output in the event of a functional safety fault on ECU or micro SW.
We first looked at the INT pin, but If Micro SW can not be trusted (i.e out of control micro or faulty logic), the concern was that the micro can’t be trusted to configure this pin as an input (via register 0x0011) for safety disabling of Ethernet.
Can the RESET_N pin held low be used as a hardware disable of the Ethernet PHY to guarantee disabling of Ethernet transmissions in case of a functional safety event?
- Is there any other hardware strategy that we could use to disable the Ethernet in the case where micro SW can't be trusted for configuration?
Thanks for the help!
David
