Part Number: DP83TC811R-Q1
Hi Team,
When the 811 is in shutdown mode (EN = Low), what are the pin states and pull up values/status? This is not listed in the table below:
Thank you,
Jared
Hi Team,
Thank you,
Jared
Hi Jared,
I am checking with the team on this. In the meantime, are there any specific pins in which you are most concerned about?
David Creger
Thank you for the support David. At a minimum, any pin with a pull (either up or down).
Hi Jared,
We do not currently have data for this, but are working to get some estimate numbers from simulation. I will get back to you as soon as I hear back from design.
David
Hi David,
Thanks for the note. Ford the pin states, is that something you also need to get from simulation?
-Jared
Hi Jared,
Yes, we will need to get the pin states from simulation and are working on doing so. I will get back to you as soon as possible.
-David
Hi David,
Can I please receive an update on this? This is becoming rather urgent..
Jared
Understood. This is in the hands of design now to perform the simulation, but I will message them again to convey the urgency.
David
Hi David,
Would it be possible to please provide an update on where things are at with the simulations?
-Jared
Hi Jared,
Design says they are completely occupied with other tasks for the next 2 weeks at least, and are asking to buy time. I have been trying to get a better estimate for timeline but have not heard back. I asked for another update today.
David
Hi Jared,
Design is saying they are occupied with other high priority tasks and gave us an estimate of March 4th for the completion of this task. Can you forward this information to the customer to see if that is acceptable?
-David
Hi David,
Is the team still on track to provide this by March 4th?
Thank you,
Jared
Hi Jared,
I have requested an update from design and will get back to you ASAP.
David
Hi Jared,
Design has not had time to get around to this unfortunately. The new estimated completion date is March 18th. I will attempt to measure the pin states by hand in the meantime.
David
