Part Number: DS90UB949A-Q1EVM
Other Parts Discussed in Thread: ALP
Team,
so I understand by default you need to have the downstream / deserializer connected or force bit 6 of reg 5C >> this should get you HPD pin toggle on the GUI
Then you also need the matching EDID to the HDMI transmitter if the later cares about resolution negotiation (which likely the case for a laptop).
By default the only one programmed is 720p60, can you please provide the script on how to write new resolution code to the EDID ? is there a standard repository of EDID code for standard resolution like 1080p60 or 2048x1024p60 ?
Once we have this, can you please provide a screenshot of the UI homepage (HPD/ frequency stable ...)
thanks
