Part Number: SD1983EVK
Other Parts Discussed in Thread: LMH1983, LMH1981, THS3201
Hi Team,
Could you help share the schematic file for SD1983EVK? Thanks a lot.
Tess Chen
Tess,
Schematics are in the EVM user's guide... I've attached them as a separate file here.
Derek Payne
Hi Derek,
Thanks for the support. I have two questions for the application with LMH1981 and LMH1983 as below.
Hi Tess,
The usage of those pins are described in the datasheet, their waveforms will vary with different video formats.
If the FPGA can reproduce the same analog video signal output to the next card, this is the preference solution as the output signal is jitter free.
Otherwise, you need some video amplifiers to distribute the video signal to the next card. Jitter will be carried forward to the next card.
