Part Number: DP83TD510E
I'm using the DP83TD510E. The datasheet has an example layout footprint that includes 5 vias in the thermal pad. Is the thermal pad needed for heat sinking? Do I really need the 5 vias shown?
I know the thermal pad is required to be soldered to GND as it is the only GND connection on the chip. The datasheet says, "vias are optional depending on application, refer to device data sheet." Not very helpful.
Cyrus
