Part Number: TUSB8044A
Hi team,
My customer is considering using TUSB8044A with AM437x, and got questions on register setting method.
Could you please take a look below?
Please note the customer is referring to TUSB8044AEVM design.
[Q1] They might need to change register setting from the default value.
From the TUSB8044AEVM User’s guide, it seems that initial setting for configuration register is done through EEPROM.
However, the customer want not to implement EEPROM on the final design.
Is it possible to change setting by MPU through I2C, without EEPROM?
[Q2-a] If the answer for Q1 is Yes, then how can we do that?
Is there any material showing the steps?
[Q2-b] If the answer for Q2 is No, then does that mean implementation of EEPROM (like EVM) is necessary?
Could you share how we can change the register setting, when changing it through MPU is impossible?
Kurumi
