Part Number: DP83620
Other Parts Discussed in Thread: DP83630, DP83822HF, DP83822IF
Hi Team,
We would like to ask your help regarding our customer's inquiry below.
I have a CPU that supports one MII interface. I need to provide a 10/100 Base Tx as well as a 100Base FX interface, but only one needs to operate at any given time which I should be able to select using a simple method. How can I achieve this using DP83620 or DP83630? You can also suggest any other Ethernet Phy in addition to DP83620/DP83630 to achieve the same. Using two independent phy is also permitted but selection should be simple.
Regards.
Danilo
