Part Number: TPS65994QFNEVM
Other Parts Discussed in Thread: TPS65994, TPS65988
Hi all :
I applied for the tps65994 Application Customization Tool form Ti website 3 days ago,
but i haven't received any response, can anyone help me?
Hi all :
I do not see your request. Would you be able to give some information on your end equipment and how you are wanting to use the PD controller?
The TPS65994 is intended for USB4 and Thunderbolt 4 (TBT4) PD3.0 applications. If your system is not implementing USB4 I unfortunately cannot grant you access to the GUI and configuration tool. I recommend using the TPS65988 which is another dual port USB Type-C PD controller, and may be a better fit for a multi-channel usb pd charger
Unfortunately since you are not following an Intel USB4 reference design for this generation, we cannot grant you access to the tool. I apologies for the inconvenience.
