Part Number: DS90UB953A-Q1
Other Parts Discussed in Thread: DS90UB953-Q1
We have designed a board using DS90UB953-Q1 Serializer. Due to the availability issues, we are planning to use DS90UB953A-Q1 for our current production.
We have compared both the datasheets to find the differences. There does not seem to be any major differences except the below new specifications given in DS90UB953A-Q1 datasheet under recommended operating conditions.
We could not understand clearly about what is specified here. Can you please clarify?
As per the description, We think it specifies the temperature range between which the PLL of the IC stays locked.
i.e, If the device powers ON or resets and PLL calibration is done at -10degC, it will stay locked as long as it operates between -30degC and -10degC. If the ambient changes to above -10degC, the PLL lock will fail and device operation will be failed. Can you please confirm if this is the meaning of the above specifications?
Sivaraj
