Part Number: SN75DP159
Would you please help review below SN75DP159 schematic?
1. What are the pullup/pulldown resistors on the control pins?
2. Please make sure you have common mode choke and ESD on the output
3. Some monitors have leakage on the HPD when they are off, you may want to add a FET switch to gate off the HPD leakage
4. Does the source support DDC clock stretching? If not, then you will need to implement the DDC snooping option.
David
