Part Number: DS250DF230
Hi All,
Is there a difference between DS250DF230ZLS and PD250DF230ZLS?
I would like to confirm the following description in the past Rev. data sheet.
Ishiwata
Hi All,
Ishiwata
PD250DF230ZLS is pre-production part number. I don't believe it is orderable anymore.
Rodrigo Natal
Thank you for your reply.
Are the contents of the product the same? Or has it been revised?
Can I use PD250DF230ZLS in the same way as DS250DF230ZLS?
The customer has PD250DF230ZLS in stock and wants to see if it can be used.
Ishiwata
Yes, some minor IC changes happened between these two versions. We do not recommend using PD250DF230ZLS for production; this version should only be used for internal development and DVT.
Rodrigo Natal
