Part Number: SN75DP159
Hi team
Could you help check what is the recommended trace length for high-speed signals? The D/S only highlights the length match but does not give a length range.
Hi team
It depends on the insertion loss of the input trace. The DP159 can support max of 15dB equalization when in adaptive equalizer mode. They need to make sure the insertion loss of the trace length is within this range.
David
