Part Number: TPD2E001
Hi team,
Could you share the recommended layout design for SON (DRY) package?
Datasheet has the one for DRL only.
Kurumi
Hi team,
Kurumi
Hey Kurumi,
We are on holiday here in Dallas today. The appropriate engineer will provide a response when we get back on Monday 4/18.
Thanks!
Rami
Hi Kurumi,
The DRY package layout will be very similar to the DRL layout since the pin positions are the same. The main difference would be the trace size will be different and the traces will be closer together since the pins are closer together in the DRY package. IO1 would also route through pin 5 on the DRY package, but that won't make a difference since pin 5 is N.C.
Matt Smith
Hi Matt,
Understood, thank you so much for your support!
Kurumi
