TCA9535 communications with I2C master device
Other Parts Discussed in Thread: TCA9535, TXS0102, PCA9306, TCA6416A
Hi there,
If I want to use TCA9535 in a 5V supply voltage (Vcc) environment, and have it communicating with a 3.3V I2C master device (MCU), do I need voltage level translators
or level shifters for the I2C signals to allow proper communication?
If yes, do you have any application notes for this?
Please kindly advise, thanks.
  • If your MCU can handle 5V signals, you could use 5V pull-ups on the SDA/SCL lines.
    However, you cannot use 3.3V signals to communicate with the TCA9535, since the VIH for the TCA is 3.7V [Vcc*0.7] for a 5V VCC.
    If you MCU IOs are not 5V tolerant, I would recommend using the TXS0102 or the PCA9306 for voltage translation.
    I do not know of any application notes, but if there are further questions, please post them here!
  • Hi Hattie.
    I understand this device TCA9535 has Vcc supply voltage of 1.65 to 5.5V.
    If MCU SDA/SCL line is at 3.3V, can I fix TCA9535 at 3.3V as well?
    In such case, I would not need an external voltage translator or TCA6416A already.
    Would fixing 3.3V for TCA9535 Vcc operation has any issue on the I/O ports and the SDA/SCL line?
    Please kindly advise.
  • Yes, you can set the VCC of the TCA9535 to 3.3V so that it communicates at 3.3V levels on the SDA and SCL lines.
    The IO ports will have a VOH of around 3.3V (VCC). But they will also be 5V tolerant.
  • If I have Vref1 connected to 3.3V and Vref2 connected to 5V, can I connect EN to 3.3V? The datasheet only shows application circuits where 5V is connected to EN (via a 200k series resistor), but my MCU outputs 3.3V. Thanks.
