Part Number: DP83869HM
Table 11 of the datasheet shows the PHY_ADD strap table for PHY_ADD3, PHY_ADD2, PHY_ADD1, and PHY_ADD0. But the PHY_ADD is actually 5-bits wide. How is the upper PHY_ADD bit controlled during power-up/reset?
Hi Mitch,
Thank you for getting in touch with us.
DP83869HM has support only for 4 bits of PHY_ADDR (Address support from 0x0 to 0xF). I see that there are some typos in the datasheet which I'll propose to get corrected in the next version of the datasheet.
Gokul.
