Other Parts Discussed in Thread: LMH0302, LMH0307, LMH0397
Hi Team
We need a two 3G - SDI outputs (1080p and 60FPS)
In our previous reference design for each SDI output, they used a separate driver IC (LMH0302). Please find the snippet for a better understanding.
In the new design, we planned to use a single LMH0302 driver IC for two SDI outputs. Basically, Connecting SDO(Bar) to another BNC connector. Please find the snippet for a better understanding.
- I like to know if any issues will come while driving two SDI outputs from a single LMH0302SQE/NOPB?
- What do I need to consider while doing this change? (Layout wise) - It should be routed 150ohm differential pair output or each should be a 75 Ohm single-ended output.
Praveen
