Part Number: DP83867CS
Other Parts Discussed in Thread: TPS74701
I am using a DP83867CS connected to an NXP LS1012a using SGMII 4-wire mode.
Initially I had difficulty with RX packets silently being dropped. I added the strapping on RX_CTRL as indicated on this forum post, which resolved this issue:
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/490569/c6678-dsp--dp83867-phy-sgmii-link-up-issue
After modifying the strapping, I now have no problem with the link and it would appear I am no longer seeing packet loss.
My questions are as follows:
For SGMII is it required for the local 25Mhz oscillator to be synchronous to the SGMII signals?
When I examine the PHY's 0x37 register it is always 0x40, Does this indicate other issues with the SGMII connection?
Do I need any other strapping not indicated in the data sheet for reliability or other recommendations?
Here is our schematic:
Thanks in advance for your attention
