Part Number: DS90UB960-Q1
Other Parts Discussed in Thread: ALP
A 953 camera is connected to the 960 deserializer,At first, the image output is normal, and then the probability data stream is disconnected.At the same time, it is found that bit [5] of 0x4d register on 960 is enabled. Its description is as follows:
Bi-directional Control Channel CRC Error Detected
This bit indicates a CRC error has been detected in the forward control channel. If this bit is set, an error may have occurred in the control channel operation. This bit is cleared on read.
Why is it normal at first, and then this bit will suddenly report an error? What causes this person to make a mistake?
Thanks.
