Part Number: DS90UB662-Q1
Hi team,
My customer use 662 pairing with 633. We met below issue, like below figures. Since I am new to camera serdes, could you kindly tell me the debug directions? Thanks!
662 pattern is ok.
BR
Jiawei
Hi team,
662 pattern is ok.
BR
Jiawei
Hi team,
Could you kindly give some comments here? Thanks!
Jiawei
Hello Jiawei,
Typically camera distortions are something to do with the sensor or SoC. Can you try to use the patgen in the 662 that to see if the issue persists?
Nick
Hi Nick,
Thanks for your reply! 662 pattern is ok, can we get the result of the issue was caused by camera?
BR
Jiawei
Hi Jiawei,
If the pattern generator is working properly and there are no errors being recognized by the 662 then I suspect the issue is not with our devices. You can read back registers of the 662 to verify we are not receiving errors.
Nick
Hi Nick,
Below is the comparison between normal and abnormal 662 register. Left is normal and right is abnormal. Seems strange.
BR
Jiawei
Hello Jiawei,
These are not public registers I cannot discuss them here but we do not change any CSI data or DVP data so we can not affect the video data in any way.
Nick
Hi Nick,
Thanks for your reply, the e2e is internal, why we can't discuss here?.
For 4*633>>662 application, we met above issue, and I did 662 pattern and found the pattern is ok. Below is the register dump of 662, could you kindly give some comments on it?
Since customer are very push on this, do we have any other way to analysis the issue? Thanks!
BR
Jiawei
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 05 00 00 00 00 00 00 00 00 ..??.?.?........ 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c0 02 00 .?q?.. ....?8??. 50: 00 00 00 00 00 00 00 00 58 00 00 00 00 00 00 00 ........X....... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 00 00 00 00 c5 00 01 00 00 c1 00 00 00 ???....?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 51 e3 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 Q?.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 3f 60 f2 00 02 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 05 00 00 00 00 00 00 00 00 ..??.?.?........ 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c0 02 00 .?q?.. ....?8??. 50: 00 00 00 00 00 00 00 00 58 00 00 00 00 00 00 00 ........X....... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 00 00 00 00 c5 00 01 00 00 c1 00 00 00 ???....?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 03 2f 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ?/.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 06 60 f2 00 03 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.?....??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 05 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 0f 00 00 00 00 00 00 00 00 ..??.?.?........ 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c0 02 00 .?q?.. ....?8??. 50: 00 00 00 00 00 00 00 00 58 00 00 00 00 00 00 00 ........X....... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 00 00 00 00 c5 00 01 00 00 c1 00 00 00 ???....?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: ff ff 63 4a ff ff 00 20 00 00 00 00 00 00 00 00 ..cJ... ........ a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 2f 60 f2 00 02 00 00 00 00 00 00 00 00 .C?/`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 05 00 00 00 00 00 00 00 00 ..??.?.?........ 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c0 02 00 .?q?.. ....?8??. 50: 00 00 00 00 00 00 00 00 58 00 00 00 00 00 00 00 ........X....... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 00 00 00 00 c5 00 01 00 00 c1 00 00 00 ???....?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 0e a0 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ??.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 02 60 f2 00 03 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 00 00 00 00 00 00 00 00 00 ..??.?.......... 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c3 45 2a .?q?.. ....?8?E* 50: 00 00 00 00 00 00 00 00 58 00 00 b0 00 00 00 00 ........X..?.... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 03 20 0a 00 c5 00 01 00 00 c1 00 00 00 ???? ?.?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 07 c4 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ??.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 04 60 f2 00 02 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 00 00 00 00 00 00 00 00 00 ..??.?.......... 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c3 04 2a .?q?.. ....?8??* 50: 00 00 00 00 00 00 00 00 58 00 00 b0 00 00 00 00 ........X..?.... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 03 20 0a 00 c5 00 01 00 00 c1 00 00 00 ???? ?.?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 90 87 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ??.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 04 60 f2 00 02 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 00 00 00 00 00 00 00 00 00 ..??.?.......... 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c3 04 2a .?q?.. ....?8??* 50: 00 00 00 00 00 00 00 00 58 00 00 b0 00 00 00 00 ........X..?.... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 03 20 0a 00 c5 00 01 00 00 c1 00 00 00 ???? ?.?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 01 dc 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ??.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 04 60 f2 00 02 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f 09 00 ff `.?@??.???zz??.. 10: 00 00 00 00 00 00 00 00 01 09 f6 09 f6 00 04 02 ........?????.?? 20: b0 3c 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ?<?............. 30: 00 00 01 01 00 03 00 00 00 00 00 00 00 00 00 00 ..??.?.......... 40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c3 04 2a .?q?.. ....?8??* 50: 00 00 00 00 00 00 00 00 58 00 00 b0 00 00 00 00 ........X..?.... 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 8a 88 .............??? 70: 1e ec e4 03 20 0a 00 c5 00 01 00 00 c1 00 00 00 ???? ?.?.?..?... 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 90: 07 9a 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ??.............. a0: 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 .....?.......... b0: 1c 3a 15 08 25 00 18 00 8e 33 83 74 80 00 00 00 ?:??%.?.?3?t?... c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ d0: 00 43 94 04 60 f2 00 02 00 00 00 00 00 00 00 00 .C??`?.?........ e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
It looks like register 0x4E is showing CSI errors in one of the dumps you attached. This still points to it being an issue with the sensor itself and not our device. Is there any way for them to test the sensor directly with the SOC? Again we do not do anything with the CSI data other than pass it through. Also try looking at the serializer registers as well to see what errors we are reporting.
Nick
Hi Nicholas,
Thanks for your reply. We still don't close this issue, I do need your support here, thanks! I ask customer re-dump 633&662 registers of abnormal and normal, see below attached. I have several questions need your help:
IHU519G:/system/bin # ./i2cdump -f -y 4 0x30 662 first registers dump
No size specified (using byte-data access)
10: 00 00 00 00 00 00 00 00 01 06 a3 06 a3 00 04 02 ........?????.??
30: 00 00 01 01 00 03 00 07 00 00 00 00 00 00 00 00 ..??.?.?........
40: 00 a9 71 01 00 00 20 00 00 00 00 12 24 83 45 2a .?q?.. ....?$?E*
50: 00 00 00 00 00 00 00 00 d8 00 00 b0 00 00 00 00 ........?..?....
70: 1e ac e4 03 20 0a 00 c5 00 01 00 00 c1 00 00 00 ???? ?.?.?..?...
90: 0d d7 00 01 ff ff 00 01 00 00 00 00 00 00 00 00 ??.?...?........
d0: 00 43 94 05 60 f2 00 02 00 00 00 00 00 00 00 00 .C??`?.?........
IHU519G:/system/bin # ./i2cdump -f -y 4 0x58 633 first registers dump
00: b0 30 20 c5 80 14 60 00 00 00 00 00 15 55 35 00 ?0 ???`.....?U5.
10: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
20: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
30: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
40: b0 30 20 c5 80 14 60 00 00 00 00 00 15 55 35 00 ?0 ???`.....?U5.
50: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
60: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
70: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
80: b0 30 20 c5 80 14 60 00 00 00 00 00 15 55 35 00 ?0 ???`.....?U5.
90: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
a0: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
b0: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
c0: b0 30 20 c5 80 14 60 00 00 00 00 00 15 55 35 00 ?0 ???`.....?U5.
d0: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
e0: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
f0: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
IHU519G:/system/bin # ./i2cdump -f -y 4 0x30 662 second registers dump
40: 00 a9 71 01 00 00 20 00 00 00 00 12 24 83 04 2a .?q?.. ....?$??*
90: 01 1a 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ??..............
IHU519G:/system/bin # ./i2cdump -f -y 4 0x58 633 second registers dump
90: 10 46 00 01 ff ff 00 01 00 00 00 00 00 00 00 00 ?F.?...?........
IHU519G:/system/bin # ./i2cdump -f -y 4 0x30 633 second registers dump
90: 01 34 00 00 ff ff 00 00 00 00 00 00 00 00 00 00 ?4..............
BR
Jiawei
Hi Nick,
Could you kindly give some comments here? Customer are very pushing on this, thanks!
BR
Jiawei
Hi Jiawei,
There are no differenced in the dumps you provided. I feel this is an issue with the sensor itself. We simply recreate the sensor data at the other side of the link. Think of it as a pipe.
Nick
