Part Number: THVD1550
Hi Expert,
May I know why does this device need R1,R2(=10ohm) in series with signal trace?
BR,
Aaron Chen
Hi Expert,
BR,
Aaron Chen
Hi Clemens,
How does it work?
How could I determine this resistance?
BR,
Aaron Chen
This depends on the actual voltage of the surges and on the clamping voltage of the TVS. But the former is hard to estimate, and the resistance must not be so high as to attenuate the signal, so 10 Ω is a value that is typically chosen.
Hi Aaron,
Clemens in correct - it is dependent on surge values - but a typical resistance, if series resistances are used, is about 10 ohms. You don't want too go to much higher or the DC losses could bring too much attenuation. These resistors, as mentioned, aren't always required, but if used should be relatively small.
If you have any other questions please let me know!
Parker Dodson
