TUSB2551A Transceiver USB Eye Diagram Cleanup Capability
Other Parts Discussed in Thread: TUSB2551, TUSB2551A, TUSB2036
Will the transceiver cleanup this eye diagram to allow meeting USB compliance?
  • Jeff,
    The TUSB2551 may be able to help, but only if you are currently using an external transceiver already?  A transceiver is not specifically intended as a means to clean-up signal intgrety issues - it is the PHYsical layer of the complete USB device.
    Can you please describe the system implementationyou are currently testing?  If your system consists of a fully integrated single chip solution, then the TUSB2551A will not help.
    The image is difficult o amke out - what USB speed are you running at?
  • Dan,
    From what you are describing, sounds like 2551 is not a solution for my application.
    Application is Stellaris LM3S9B96 C5 version embedded USB peripheral running at full speed.
  • Jeff,
    Correct on TUSB2551A
    The TUSB2036 hub could be a potential option depending on your power arrnagement.
