TIOS101: OUT pull-up/down current
Part Number: TIOS101
TOIS101 datasheet specifies "OUT pull-up/down current" as 50uA.
My customer would like to know where this leakage current come from in the device to understand this device behavior.
Could you please explain it?
Oba
  • Hi Oba-san,
    When EN is low, there is still some very slight biasing that might show up on OUT for the TIOS101. In other words, if EN = LOW, IN = LOW, and you force OUT = HIGH, the leakage current here is pull-down current. Alternatively, if EN = LOW, IN = HIGH, and you force OUT = LOW, the leakage current in that case is pull-up current.
    If IN = OUT then you should not see leakage pull-up or pull-down current on this pin.
    Danny
