Part Number: TCAN1145-Q1
Hi team,
My customer is using TCAN1145-Q1 in their OBC application and would like to configure selective wakeup through WUF. When the OBC machine is power up and host PC send the correct wakeup frame 0x5xx as configuration, TCAN1145 can be wake up normally. If send other frame like 0x333, TCAN1145 will not be wake up.
The problem is, when customer power down the OBC machine and host PC still constantly sending out the incorrected wakeup frame 0x333. If the OBC is powered up at this time, the IC will be wake up by this wrong frame, showing INH high and CANINT high. Is it related with some power up sequence requirement? Is their any way to configure the device not to be wake up by wrong frame in this case?
Scarlett
