Part Number: DS50PCI401
Hello TI team
I would like to know if this IC can be used for SLVS-MI signal lines.
According to the data sheet, it can be received the differential signal if the peak to peak is 0.1V or higher. Is this correct?
And is it possible to meet the SLVS specifications (CM voltage 200 mV, differential voltage 400 mVp-p) as an output signal?
