Part Number: DP83TG720R-Q1
We found consistent fail results in MDI mode conversion when testing our board with the DP83TG720R using STP cable.
If we look at TI's test report for DP83TG720, the MDI mode conversion test showed PASS results.
One of the main difference is that the DP83TG720 evaluation board (in the test report) was using UTP cable (MATEnet connector and cable).
We suspect that this may be related to the common mode impedance difference between STP and UTP cable assembly.
On our board and TI evaluation board (media converter board), we adopted this MDI termination design (as in the snlu289 User’s Guide DP83TG720 Media Converter Evaluation Module):
In this termination, the common mode impedance will be ~500ohm.
For a UTP (MATEnet) cable, we have measured that it is in the range of ~350ohm:
For a STP cable, due to the shielding, it is typically much lower at 30 ~40ohm range:
Hence we are wondering if DP83TG720 are meant for UTP or STP cable?
If it is to be used for STP cable, should we ignore the MDI mode conversion test in this case, as it may not be relevant.
Or there is another recommended termination design required for STP?
Please advice. Thanks!
